184
Alt skrevet av ZoRaC
IDLock 101 / OZW / HASS - access control notification parameter
ZoRaC svarte på Tor Magnus sitt emne i Z-Wave
I følge låsens spesifikasjoner, så sender den info om dette. HomeSeer bare ignorerer det... -
Hmm... ikke som jeg vet... @Moskus?
Ser egentlig ikke slik ut, se "duration": From Until Duration Value Was And Became Change Device String 30/01/2018 19:22:17 30/01/2018 19:24:55 00:02:38 On Off -- No Status 30/01/2018 19:20:01 30/01/2018 19:22:17 00:02:16 Off On -- No Status 30/01/2018 19:17:53 30/01/2018 19:20:01 00:02:08 On Off -- No Status 30/01/2018 19:15:11 30/01/2018 19:17:53 00:02:41 Off On -- No Status 30/01/2018 19:13:28 30/01/2018 19:15:11 00:01:43 On Off -- No Status 30/01/2018 19:10:22 30/01/2018 19:13:28 00:03:06 Off On -- No Status 30/01/2018 19:09:04 30/01/2018 19:10:22 00:01:18 On Off -- No Status 30/01/2018 19:05:27 30/01/2018 19:09:04 00:03:36 Off On -- No Status 30/01/2018 19:04:39 30/01/2018 19:05:27 00:00:48 On Off -- No Status 30/01/2018 19:00:38 30/01/2018 19:04:39 00:04:01 Off On -- No Status 30/01/2018 18:55:55 30/01/2018 19:00:38 00:04:43 On Off -- No Status 30/01/2018 18:55:43 30/01/2018 18:55:55 00:00:11 Off On -- No Status 30/01/2018 18:51:30 30/01/2018 18:55:43 00:04:13 On Off -- No Status 30/01/2018 18:50:54 30/01/2018 18:51:30 00:00:36 Off On -- No Status 30/01/2018 18:47:06 30/01/2018 18:50:54 00:03:48 On Off -- No Status 30/01/2018 18:46:05 30/01/2018 18:47:06 00:01:01 Off On -- No Status 30/01/2018 18:42:41 30/01/2018 18:46:05 00:03:23 On Off -- No Status 30/01/2018 18:41:10 30/01/2018 18:42:41 00:01:31 Off On -- No Status 30/01/2018 18:38:17 30/01/2018 18:41:10 00:02:53 On Off -- No Status 30/01/2018 18:36:21 30/01/2018 18:38:17 00:01:56 Off On -- No Status 30/01/2018 18:33:52 30/01/2018 18:36:21 00:02:28 On Off -- No Status 30/01/2018 18:31:26 30/01/2018 18:33:52 00:02:26 Off On -- No Status 30/01/2018 18:29:28 30/01/2018 18:31:26 00:01:58 On Off -- No Status 30/01/2018 18:26:37 30/01/2018 18:29:28 00:02:51 Off On -- No Status 30/01/2018 18:25:03 30/01/2018 18:26:37 00:01:33 On Off -- No Status 30/01/2018 18:21:42 30/01/2018 18:25:03 00:03:21 Off On -- No Status 30/01/2018 18:20:39 30/01/2018 18:21:42 00:01:03 On Off -- No Status 30/01/2018 18:16:53 30/01/2018 18:20:39 00:03:46 Off On -- No Status 30/01/2018 18:16:15 30/01/2018 18:16:53 00:00:38 On Off -- No Status 30/01/2018 18:12:03 30/01/2018 18:16:15 00:04:11 Off On -- No Status 30/01/2018 18:07:30 30/01/2018 18:12:03 00:04:33 On Off -- No Status 30/01/2018 18:07:09 30/01/2018 18:07:30 00:00:21 Off On -- No Status 30/01/2018 18:03:05 30/01/2018 18:07:09 00:04:03 On Off -- No Status 30/01/2018 18:02:19 30/01/2018 18:03:05 00:00:46 Off On -- No Status 30/01/2018 17:58:41 30/01/2018 18:02:19 00:03:38 On Off -- No Status 30/01/2018 17:57:25 30/01/2018 17:58:41 00:01:16 Off On -- No Status 30/01/2018 17:54:16 30/01/2018 17:57:25 00:03:08 On Off -- No Status 30/01/2018 17:52:35 30/01/2018 17:54:16 00:01:41 Off On -- No Status 30/01/2018 17:49:52 30/01/2018 17:52:35 00:02:43 On Off -- No Status 30/01/2018 17:47:46 30/01/2018 17:49:52 00:02:06 Off On -- No Status 30/01/2018 17:45:28 30/01/2018 17:47:46 00:02:18 On Off -- No Status 30/01/2018 17:42:51 30/01/2018 17:45:28 00:02:36 Off On -- No Status 30/01/2018 17:41:03 30/01/2018 17:42:51 00:01:48 On Off -- No Status 30/01/2018 17:38:02 30/01/2018 17:41:03 00:03:01 Off On -- No Status 30/01/2018 17:36:39 30/01/2018 17:38:02 00:01:23 On Off -- No Status 30/01/2018 17:33:07 30/01/2018 17:36:39 00:03:31 Off On -- No Status 30/01/2018 17:32:14 30/01/2018 17:33:07 00:00:53 On Off -- No Status 30/01/2018 17:28:18 30/01/2018 17:32:14 00:03:56 Off On -- No Status Jeg kjører også fw 1.8.
Temperaturmåler med ekstern sensor som støttes av rfxtrx433
ZoRaC svarte på mk1 black limited sitt emne i Klimakontroll
HomeSeer med JowiHue-plugin og ConBee (deCONZ). Begge på hver sin Ubuntu-server. -
Jeg har bestilt 3 slike, men ikke fått dem enda. Fra før har jeg en av den forrige modellen, men har hatt den i drift i bare et par uker: https://www.aliexpress.com/item/Original-Xiaomi-Mi-Smart-Temperature-and-Humidity-Sensor-Put-the-baby-Home-office-Work-With-Android/32812414719.html -
Senke termostater når prisen er høy?
ZoRaC svarte på ZoRaC sitt emne i Strømsparing og strøm-overvåkning
Joda, men 0,5-1 grad på en time eller to trenger ikke merkes noe særlig. ? -
For å være sikker, så la jeg til gruppe 2 mot HomeSeer igjen tidligere i dag. Termostaten er innstilt på 25 grader og temp har steget pga klesvask: På 4 timer sier den at den har byttet mellom on/off 50 ganger, mens realiteten trolig er at den har vært «off» hele tiden.
Det har jeg forsøkt, men den røde lysdioden i termostaten og statusen i HomeSeer matcher ikke. Mener noen hadde spurt produsenten også og fått beskjed om at det ikke var mulig...
Jeg bruker pfSense med Suricata på routeren og Bitdefender på PCene. HS-serveren bruker jeg bare Ubuntu sin innebygde brannmur på (UFW).
Da ville jeg byttet til noe annet. En brannmur som blokkerer ting uten at du kan «overstyre» er jo ganske ubrukelig...
Men det er jo absolutt ikke noe man ønsker å gjøre, da er jo huset tilgjengelig for hvem som helst! Ekstra ille er det når det ikke der ut til å være kryptert heller. Det ser ut til at My Domoticz er en bedre løsning.
Ok, det ser ut til å være riktig adresse i hvertfall. Den virker om du prøver den på selve serveren? I så fall er det trolig en brannmur som blokkerer tilkobling fra andre maskiner. Kjører du Windows på serveren?
På serveren, start cmd, skriv «ipconfig». Da skal du få opp en IP-adresse som trolig starter med 192.168 eller 10.0. Prøv å skriv inn den adressen i nettleseren på serveren. Hvis det funker, prøv fra en annen PC. PS: Dette vil bare fungere fra maskiner på samme nettet, ikke over Internett fra andre steder.
Ser ut til at du kanskje kan hviteliste «Homeseer.exe»: https://community.sophos.com/products/sophos-central/f/sophos-central/87514/application-control---whitelisting-threats
127.0.0.1, også kalt «localhost», er ALLTID samme maskin som du sitter på. Sjekk hva IP-adressen til serveren din er og prøv å logg på via den. Den er visst bare i beta og krever at du har registrert deg først: http://domoticz.com/wiki/MyDomoticz
Så alt annet mot web fungerte? Tror plugins ligger hos utviklerne, så alle ligger på forskjellige adresser/servere. Er det tilfeldigvis Suricata eller Snort du bruker som brannmur via pfSense?
ZoRaC svarte på roarfred sitt emne i Strømsparing og strøm-overvåkning
Rart at selskapene kan innføre timesbasert fakturering når som helst mellom 2017 og 2019 (altså når AMS-måler installeres), men å gi kunden tilgang til sitt momentanforbruk er de pålagt å gjøre først fra 2019...! -
«StatusTrackingNormal» (se skjermbildet).
Jeg bruker noen Nexa WTE-2, men det er ikke Z-wave.
- 10 svar
Mine har god rekkevidde og god batteritid (ikke byttet enda etter 1,5 år). De feilmålingene er kanskje så sjeldne/kortvarig at det ikke har noe å si for termostatstyring...? Har uansett bestilt nye Xiaomi temp/fukt-sensorer nå, men de er ZigBee og har ikke ekstern probe, så vil nok uansett ikke hjelpe @mk1 black limited... -
Jeg har også 3 stk, men hadde ikke merket noe sånt. Sjekket «Device History» på den ene ett år tilbake - har visst vært både -47,9 og +47,9... -
Ja, det er det store spørsmålet... vil det koster mer med «vedlikeholdsvarme» i dyre perioder eller vil det koste mer å varme opp en ekstra grad når prisen har sunket igjen...? Når effektleddet kommer vil jeg nok gjøre noe tilsvarende. -
Et lite tips hvis noen skal ha en elektriker i hus: få satt inn en DIN-montert stikkontakt i sikringsskapet med det samme. Da står man ganske fritt når det kommer til utstyr for å koble til HAN-porten, for da kan man ha ekstern strømforsyning til den. -
https://m.clasohlson.com/no/Temperaturgiver-hygrometer/36-1797 -
Ja. Husker ikke i farten akkurat hvordan, men mener det er et valg som heter «StatusText». Der kan man velge alternativ tekst og farge basert på verdi.
