ZoRaC
Crew
Alt skrevet av ZoRaC
  1. Aug-01 15:15:47 TibberSeer Debug Initializing done! Ready... Aug-01 15:15:47 TibberSeer Debug RestartTimer, diff: 852978 Aug-01 15:15:47 TibberSeer Debug UpdateTibberData done (root 1646)! Aug-01 15:15:47 TibberSeer Debug RestartTimer, nextWhole: 15:30:00 Aug-01 15:15:47 TibberSeer Debug RestartTimer, timeNow: 15:15:47.0216470 Aug-01 15:15:47 TibberSeer Debug UpdateTimerTrigger done. Aug-01 15:15:47 TibberSeer Debug UpdateTibberData starting (for root884)... Aug-01 15:15:47 TibberSeer Debug UpdateTibberData starting (for root880)... Aug-01 15:15:47 TibberSeer Debug UpdateTibberData starting (for root1646)... Aug-01 15:15:46 TibberSeer Debug StartLiveMeasurementListener done! Aug-01 15:15:41 TibberSeer Debug UpdateTimerTrigger timer lapsed. Updating Tibber-data. Aug-01 15:15:41 TibberSeer Debug CheckAndCreateDevices done! Aug-01 15:15:41 TibberSeer Debug Found consumption root: 884 Aug-01 15:15:41 TibberSeer Debug Updating Status Graphics... Aug-01 15:15:41 TibberSeer Debug StartLiveMeasurementListener starting... Aug-01 15:15:41 TibberSeer Debug Updating Status Graphics... Aug-01 15:15:41 TibberSeer Debug Updating Status Graphics... Aug-01 15:15:41 TibberSeer Debug Updating Status Graphics... Aug-01 15:15:41 TibberSeer Debug Updating Status Graphics... Aug-01 15:15:41 TibberSeer Debug Updating Status Graphics... Aug-01 15:15:41 TibberSeer Debug Updating Status Graphics... Aug-01 15:15:41 TibberSeer Debug Updating Status Graphics... Aug-01 15:15:41 TibberSeer Debug Updating Status Graphics... Aug-01 15:15:41 TibberSeer Debug Found price root: 880 Aug-01 15:15:41 TibberSeer Debug TibberRealtime new, root: 1646 Aug-01 15:15:41 TibberSeer Debug Found realtime root: 1646 Aug-01 15:15:41 TibberSeer Debug CheckAndCreateDevices; Found roots count: 3 Aug-01 15:15:36 TibberSeer Debug Starting initializiation. Aug-01 15:15:36 Starting Plug-In Initializing plugin TibberSeer ... Aug-01 15:15:36 Starting Plug-In TibberSeer loaded in 15089 milliseconds Aug-01 15:15:22 Info Plugin TibberSeer has connected. IP:127.0.0.1:36042 Aug-01 15:15:21 Warning I/O interface TibberSeer is down, executable is not running, restarting ... Aug-01 15:15:08 Info Plugin TibberSeer with instance: has disconnected Aug-01 15:15:08 TibberSeer Debug Tibber, SaveToRootRef. TipperPrices = TibberPriceLocale Aug-01 15:15:07 TibberSeer Debug PEDAdd, object was serialized: True Aug-01 15:15:07 TibberSeer Debug PEDAdd, object was serialized: True Aug-01 15:15:07 TibberSeer Debug Checking consumption at 01/08/2023 15:15:07 using refresh token starting with: a1b Aug-01 15:15:07 TibberSeer Debug Checking prices at 01/08/2023 15:15:07 using refresh token starting with: a1b Aug-01 15:15:07 TibberSeer Debug Tibber, SetRootData. TibberConsumptions = TibberConsumptionLocale Aug-01 15:15:07 TibberSeer Debug TibberPrice, UpdateData starting... (root: 880) Aug-01 15:15:07 TibberSeer Debug TibberPrice, GetRooTData. TibberPrices = TibberPriceLocale Aug-01 15:15:07 TibberSeer Debug UpdateTimerTrigger done. Aug-01 15:15:07 TibberSeer Debug RestartTimer, diff: 892764 Aug-01 15:15:07 TibberSeer Debug RestartTimer, nextWhole: 15:30:00 Aug-01 15:15:07 TibberSeer Debug UpdateTibberData starting (for root884)... Aug-01 15:15:07 TibberSeer Debug RestartTimer, timeNow: 15:15:07.2359350 Aug-01 15:15:07 TibberSeer Debug UpdateTibberData starting (for root880)... Aug-01 15:15:07 TibberSeer Debug UpdateTibberData done (root 1646)! Aug-01 15:15:07 TibberSeer Debug UpdateTibberData starting (for root1646)... Aug-01 15:15:06 TibberSeer Information RT --> 15:15:06 - power: 596 W, meter: 92292.767 W, today: 18.412858 kWh; cost: Aug-01 15:15:05 TibberSeer Information RT --> 15:15:04 - power: 593 W, meter: 92292.767 W, today: 18.412527 kWh; cost: Aug-01 15:15:04 TibberSeer Information RT --> 15:15:02 - power: 594 W, meter: 92292.767 W, today: 18.412198 kWh; cost: Aug-01 15:15:01 TibberSeer Information RT --> 15:15:00 - power: 594 W, meter: 92292.767 W, today: 18.411868 kWh; cost: Aug-01 15:15:00 TibberSeer Debug UpdateTimerTrigger timer lapsed. Updating Tibber-data. Vet ikke om noe av dette hjelper på å finne årsaken?
  2. Ah, du har puttet noen knapper nederst i "Configuration" ja, de hadde jeg ikke sett... 😛 Jeg hadde bare sett avkrysningsboksene under "Real time" inne på "Configuration" og antok at det bare var de man kunne slå av/på... Testet å slå av både for "price" og "consuption" nå, så får vi se hva som skjer kl 15:00... 🙂 EDIT: Nei, det hjalp ikke: Aug-01 15:00:09 Info Plugin TibberSeer with instance: has disconnected Den prøver å oppdatere "consumption" likevel. Slo på debug nå, så får vi se kl 15:15. 🙂 Jeg ser "Keep Realtime Alive" er aktiv, med satt interval på 15 min. Kanskje det er noe som skjer der...?
  3. Mulig det skyldes at jeg ikke er strømkunde hos Tibber lengre og at plugin krasjer fordi den prøver å hente data som den ikke får…?
  4. Hos meg stopper plugin hvert kvarter, hele døgnet…
  5. Fått satt opp en bryter for styring av robotstøvsugeren. 🙂 Ett trykk = start med en gang To trykk = start når huset går i borte- eller nattmodus Tre trykk på hvilken som helst knapp = støvsuger kjører til søppelbøtta for å tømmes (eller for å få fylt vann og montert mopp)
  6. Slettet du dem da fra det grafiske grensesnittet til selve deCONZ? Jeg prøvde å slette et par lys fra webgrensesnittet nå (Phozcon), men de joinet ikke Z2M…
  7. Sier du at hvis jeg sletter pæren fra deCONZ, så går pæra automatisk i «joine-modus»? 😮
  8. Holder på å migrere fra ConBee/deCONZ/JowiHue til SLZB-06/Zigbee2MQTT/mcsMQTT og det innebærer å pare alt på nytt. Etter å ha brukt 20 forsøk på hver av de første 4 IKEA-pærene kom jeg til en gammel pære med kjempegammel firmware (som betyr enda mer «kilen» på timingen i resett-prosessen). Så da måtte jeg lage en egen resett IKEA-pære event 😛
  9. Og flagget ble vinnerbidraget. https://www.eldirekte.no/nkslkaaring
  10. Det tok 5 år før første pære sluttet å virke her. Den var fortsatt «på nett», men sluttet å lyse. Dette var ikke en RGB-pære, men en «TRADFRI LED bulb E27 1000 lumen, dimmable, opal white».
  11. Kul video, @Moskus! 🙂 https://www.eldirekte.no/nkslbidrag Jeg tenkte levere et bidrag selv, men glemte det og dro på ferie. 🤦🏼‍♂️🙄
  12. Men visningsformatet setter du vel på devicen i HomeSeer? Jeg gjør det i HS3 i hvertfall…
  13. Ja, jeg brukte den «aktivt» for noen år siden til at 3-åringen kunne styre lyset på rommet sitt (av/på, farger, osv).
  14. ZoRaC
    Easee2MQTT
    Ser ut til at URL på linje 30 måtte endres: url = "https://api.easee.com/api/accounts/login" Den pekte til .cloud og /token.
  15. ZoRaC
    Easee2MQTT
    Jeg har slitt med å få det til å funke siden februar: [2023-06-30 22:12:37] INFO Script is starting. Looking for settings [2023-06-30 22:12:37] INFO Successfully opened settings. [2023-06-30 22:12:37] INFO Token expires in less than 350 seconds. Fetching a new token. [2023-06-30 22:12:37] WARNING Failed to connect to Easee. Response code: 405 Jeg får også feilmelding om jeg kjører setup.py på nytt: Please input password of Easee account: Traceback (most recent call last): File "setup.py", line 80, in <module> access_token, expiry = get_access_token(easee_username, easee_password) TypeError: 'bool' object is not iterable Noen forslag?
  16. Kjøpte den, ja. 🙂 Bestilte herfra: https://www.amazon.com/dp/B091KMT9GB/ref=pe_32293190_567121270_fxm_3_0_n_id Ikke fått den til å virke med bjella. Fikk til og med tilsendt en ny enhet fra Amcrest (ikke kameraenheten, men den som kobles i parallell på bjella), men det hjalp ikke. Den varsler uansett mobilene våre og nettbrettet på veggen (som igjen varsler HomeSeer og trigger en Nexa-bjelle), så jeg har ikke brydd meg om å feilsøke på mye. 🙂
  17. Hva bruker du for å integrere Zigbee? DeCONZ, Zigbee2MQTT eller noe annet?
  18. Hvilke protokoller har du aktivert i plugin? Enkelte protokollerer fungerer ikke sammen, så det kan jo være det som er problemet.
  19. Ja, jeg så dette og tenkte det samme. 🙂 Du får gjøre det først du da, og beskrive overgangen fra deCONZ. 😛
  20. Jeg har vel 10 stk Fibaro Dimmer 2 og mener 7-8 av dem er koblet 2-wire. Ingen bunnlast på noen av dem. Noen LED-pærer fra IKEA og Clas Ohlson.
  21. Jeg testet den i dag, ikke til å skrive kode, men jeg spurte om hvordan man kan integrere en Roborock Q7 med HS3. Og jaggu er den god til å lyve! 😂 «If you are running HomeSeer 3, you can still integrate the Roborock Q7 Max with HomeSeer using a third-party plugin called "Roborock Vacuum Plugin for HomeSeer 3".» så spør jeg om en lenke til denne: «Yes, you can find the "Roborock Plugin for HomeSeer 3" by user "spud" on the HomeSeer forums at the following link: https://forums.homeseer.com/forum/lighting-primary-technology-plug-ins/lighting-primary-technology-discussion/roborock-vacuum-plugin-spud/137947-roborock-plugin-for-homeseer-3 » Den linken funker ikke og jeg finner ikke spor av noen slik plugin noe sted. 😛 når jeg påpeker det så gir den meg en ny ugyldig link til forumet. 😛 Så ja, man må vite litt hva man driver med og ikke stole blindt på svarene man får…
  22. Du skrev motsatt… 🤭
  23. Og hvorfor vil du ha datoene på engelsk? Jeg et sikkert ikke den eneste som har engelsk oppsett på serveren, men likevel ønsker at dagene står på norsk. 🙂 Siden jeg har CI to steder (ikke sikkert det trengs med det nye formatet?), så er det vel bedre å initiere den én gang og gjenbruke den i en variabel? I tillegg er det mer lesbart på mobilen å ha det på to separate linjer, for det er på mobilen jeg som regel programmerer. 😛
  24. Er den feilmeldingen med demo-token og uten å endre noe som helst? Skal ikke trenge å gjøre noe spesielt annet enn å opprette token, men mener noen sa at man nå får flere valg om hvilken tilganger token skal få når man oppretter den. Har du prøvd å bare gi den alle tilgangene der?
  25. Den skal vise widget om du kjører den i Scriptable. Samme som meg, så det skal funke. Har du prøvd å kjøre den med den demo-token som ligger i koden? Altså uten å endre noe som helst?
